1 - 5 of 5 Posts
I am converting a 2003 WRX transmission from pull clutch to push clutch. I am using a Tilton pull slave cylinder to change the direction of the fork.
Question:
Is there a T.O. bearing that will mount to the pull fork with or without modification to the fork?
Tilton offer hydraulic throw out (release) bearing kits. Contact them directly I'd say. Jeg's sells Tilton but I don't know whether Jeg's would know the answer. Tilton should know.
I am converting it to run a 5-1/2" or 7 -1/4" dual disc carbon Tilton or 10,000 RPM clutch. There is nothing available in a light weight race clutch that uses a pull clutch.
The pull clutch fork, that uses the cross bar pivot, is much stronger than the sheet metal push fork that works with the ball.
1 - 5 of 5 Posts
