Good evening gentlemen! New to this forum and excited! I have an 11 wrx and few mods done are dw65c fuel pump with Cobb e85 kit, tgv delete, Cobb downpipe, intake, diverter valve and ngk one step closer plugs. Has been driving like a charm this whole time never had a problem until now ? not major but wanted to see if anyone has any similar issue. All of a sudden now when I go out to start it after a few days of sitting it will crank over and die immediately the first couple times, then the next 2 starts itll bog out a bit and die and then usually the 6th or so try itll bog and then catch itself and start idling fine. Drives perfect still and idles perfect just having issue starting up. I just dont understand why it sounds like it struggles to get fuel the first 5 tries and then eventually will start up. But once started I can start it again same day and no problem only when it sits for a few days. Any suggestions help!! Thanks guys
