1 - 3 of 3 Posts
I was curious if anyone had run these on their wrx's? I can get them for cheap thru work. I was plannin' on running them on all four corners w/ hawk pads and braided hoses. I'm a stage 2.5 now and will be a stage 4 by spring time and these stock brakes already aren't cutting it.
I have the Stoptechs/Rotoras (I thinkt thats what he called them) which are an off shoot of Power slot (probably wrong on that). Anyway I upgraded with Carbotech Bobs when I warped the crap out of the stock ones.
Anyway, down low speed its a little bit more spongy until theyre actually heated up. After that high speed braking is a lot better.
Rotors arent going to give you much of any improvement. Go with the pads and you should notice a difference.
1 - 3 of 3 Posts
