Hello all,
I have a 2008 subaru Impreza 2.5i.
Resently the power steering pump started to make a lot of noise.
First thing I did was drain the power steering reservoir and replaced it with automatic transmission fluid. The noise continued to happen.
Next after analyzing the situation I felt that I had a bad power steering pump so I purchased a power steering pump. Install the pump put fresh automatic transmission fluid in and the noise is still happening.
Next time I tried it was to replace the rubber o-ring on the power steering pump and the noise is still happening.
I've run out of ideas of what to do so I'm looking for any suggestions on how to get rid of the noise the video below is my car and the noise that it's currently making I believe the noises coming out of the high pressure hose.
