1 - 5 of 5 Posts
Ok, after applying Dynamat to my drivers side door, I noticed that my power door locks no longer worked. I peeled off the Dynamat where the 2 rods are located and tried the locks again, nothing! They don't work when you push the button on the door or by keyless entry. Does anyone know what might have happened or is there anyway to reset the locks? Any help is very appreciated! Thanks!
did you maybe disconnect the wires (or harness) that goes to the switch by mistake?? Or maybe while doing your dynomat install, you might have shorted something out thus blowing a fuse.
That's what I would check first, then go from there.
I know this may sound stupid but did you press the lock botton that disables all other doors from controling the windows? Just a thought.
The fuse was blown. Thanks for the help. I think the rods were rubbing something on the panel which caused the fuse to blow.
1 - 5 of 5 Posts
