1 - 5 of 5 Posts
I think I have a big problem.... soooooo I thought it would be fun to change the tune I have on my 07 sti. Everything went well with Re flashing the ecu. Until I decided to disconnect it. Negative connector is still intact but the positive connector disconnected from the wire. How can I fix it?
Æternum
Not difficult. See if you can recrimp the connector first. Alternatively, it should be trivial just to solder the connection.
Or are you saying that it disconnected in the middle of the reflash?
1 - 5 of 5 Posts
