1 - 11 of 11 Posts
So on the recommendation of a friend I plasti-dipped my stock wheels this weekend. Super cheap and easy and I think it looks bada**.
before
after
Sent from my PG86100 using Tapatalk
Æternum
Personally I would have gone with powdercoating or a stripping and painting the wheels. I'm not sure how Platidip will hold up to the elements.
Yeah I'm not sure about the longevity of plasti-dip either, but for about 20 bucks I figured it was worth testing out. Worst case I can peel the stuff off and powdercoat.
Æternum
That's true. Let us know how long it lasts.
I had it on the hood of my old vw for the past few months. its just hard to keep it clean since its textured.
Sent from my ADR6350 using Tapatalk
Always been a fan of plasti-dip.
My only thing with it is that IMO it's not a permanent solution (which I'm sure you obviously know) to me its more of a "idk if my wheels will look good black...let's plasti-dip them and see!" and if you like then, then get them properly painted/powder-coated.
Cheeky Bastage!
what would be the cause of them not lasting? Peeling from the wheels or getting torn up from rocks/elements/etc? If the latter, could you clear coat in and kinda seal it in?
Good luck, but I can't imagine that stuff lasting in that environment. Debris, heat, slop, brake dust...
Then, cleaning it off to put real paint on will be a real pita, I think.
Discussion Starter #10
Just to update those who might be interested in trying this stuff out. I've done about 500 miles in various weather conditions, as well as 3 automatic car washes and it still looks good as new. Still probably not a permanent solution, but it holds up to the elements very well.
Discussion Starter #11
Ok, just now starting to get a little peeling around the rim of the wheels where it meets the tires. I suspect hard cornering (which I tend to do a lot) is the culprit. The rest of the wheels are good as new.
1 - 11 of 11 Posts
