1 - 4 of 4 Posts
pics of gauges/pod, need help identifying some wires
now i need help determining what to do with these wires? PLEASE HELP
autometer sport comp Gauges-as it lays upside down the gauge on right is the EGT pyrometer, middle is boost controller, and left is oil pressure.
Questions?
1. what is the long braided metal wire thing in the 3rd pic used for? what connects to the black wire at the end by the tube thing?
2. also in the 2nd pic the 2 red wires are short, and do i need to strip and make it longer to connect to a positive? what to use as the positive?
3. there is a group of black wires, looks to be coming out of the light out of all three, they need to connect to a ground?
4. also group of white wires out of them all that need to connect to a positive, what to use as positive
5. theres a blue wire in the 2nd pic off the oil pressure, its long what do i connect that to and use that for?
6 and last on the long yellow wires that are red and yellow that come out of the EGT, and the probe with the red and yellow do i connect them red and red or red and yellow together, then put heat shrink over them?
AS you can tell i need much help, and i want to try and do this myself, so all the help is very much appreciated!!!
i can T in or i cant T in, ??? i need help i got all the wiring in and ready to put the EGT probe and the oil pressure sender i still need explanations with what to do to that?
Re: pics of gauges/pod, need help identifying some wires
Questions?
If you're talking about the oil pressure sender?, the black wire is used to ground the sender.
When you install teh pod in the clock location, all the wires you will need are available in the clock's harness
yes
search here and scoobymods, again, you can use the clock harness
connec that to the pressure sender
red-red/yellow-yellow would be my guess
*you CAN T the boost line in.
*put some teflon tape on the galley plug for the oil pressure
***make sure to clean the @#$^ out of the exhaust manifold after oyu drill it***
1 - 4 of 4 Posts
