1 - 4 of 4 Posts
Hello,
I recently purchased a bugeye 2002 wrx wrb. When I bought the car, it came with the front 4 pot and rear 2 pot perrin/wilwood brake kit. I just found that I need to have the brake pads and rotors changed. I went to both perrin and wilwood websites, and I can't seem to find any information about this kit. Does anyone know what pads and rotors I can use? Can I use the stock pads and rotors from a Subaru dealership? Thanks.
how many miles? You may be able to machine the rotors, and yes, you can use stock pads, the only real diff btw pads OEM and aftermarket is the material their made with and the designed grooves in them, but better to stick with what willwood or what not recommends, check their website for more info
SuperNova
Personally I'd call Perrin and ask. If you measure your rotors you'll be in better shape, as well as finding any part numbers before you call.
1 - 4 of 4 Posts
