Status
Not open for further replies.
1 - 7 of 7 Posts
ClubWRX.net Vendor
New Perrin MBC and Perrin Power Steering Responce Systems:
Perrin MBC $90
Mounted underhood, It uses a custom rate spring and industry first ceramic ball bearing for lightening quick response! Range of adjustment exceeds 30 PSI and can be used on virtually any turbocharged car. Adjustments can be made is as little as 1/4 of 1 psi! Unique locking ring and clearly marked adjustments help prevent mistakes and ease adjustments on the go. Includes silicone tubing, connectors instructions etc.
http://www.jscspeed.com/wrx/boostcontroller/perrin_mbc.htm
Perrin Power Steering Responce System $171
Positive Steering Response system. Helps control and
eliminate unwanted body squat and dive under hard cornering and
acceleration. Modifies front end alignment and uses a spherical bearing
to control wheel wandering. A must have for any WRX with larger than
16" wheels. Gone are the days of the car attempting to wander from rut
to rut! Simple installation should not exceed 1 hour for most
experienced shadetree mechanics.
Go online or call to order 717-397-4637
Autometer Triple Dash pods also in stock $45 each!
http://www.jscspeed.com/wrx/interior/gauges/autometer_clock.htm
Can you compare this to the Whiteline ALK. What does it change,Camber? Is the subframe still utilized? What type of bushing? .
ClubWRX.net Vendor
Discussion Starter · #5 ·
answers
Yes subframe is still utilized, kit comes with spacers for sub frame.
Camber will be changed so you will need re-alignment similair to the whiteline kit.
And a spherical bearing is used (like with perrins rear end links) so less noise and longer life.
I can't compare it yet to the whiteline since we just got these in but the materials and bearing are high quality so they seem like a great choice (once we install a set on a car here I will give you a more detailed report, or maybe a customer can chime in)
Go here to buy this item:
http://www.jscspeed.com/wrx/suspension/perrin_psrs.htm
1 - 7 of 7 Posts
Status
