In 1964 Pedders was literally mass producing its own brand of shocks
by simply modifying overseas designs to suit local needs.
They took the next step in 1974 by designing their own shocks.
This large, multinational automotive company has come a
long way from a backyard welding shop, and most if not
all of this growth has been due to the determination,
dedication and foresight of our most important asset - their people.
Check Out What Pedders Makes For You!
VVV
COILOVERS
The Pedders brand has been synonymous with high performance
dampers for decades. These shock absorbers and struts combine the most
advanced technology with Pedders renowned expertise in the
fine tuning of damping rates for superior handling.
LOWERING SPRINGS
With Pedders Coil Springs the handling of most vehicles is substantially
improved by increasing the original spring rate to a rate which reduces body roll
and, in turn, aids tire adhesion - without causing undue harshness or rigidity.
STRUTS
They’ve been fixing, working with, modifying and designing their own shock absorbers for
more than 60 years, so yeah, they know a thing or two about shock absorbers.
A shock absorber’s primary role is to resist movement, to control the
movement of the car’s springs and reduce body roll.
TOP HATS
Whether you are replacing OEM or upgrading to an adjustable hat, this is
one of the most overlooked parts. Get back your OEM ride or be able
to adjust your suspension to what you need for the track.
FREE UPS GROUND SHIPPING ON ALL ORDERS ABOVE $200 TO THE LOWER 48 STATES!
