1 - 3 of 3 Posts
Just so you know, Pedders is a series of shops in Oceania and Europe, a bit like the North American "Midas" chain but dealing in springs and dampers rather than mufflers.
If you are OK with that, then there is still the issue of the link not working. However, I'm not in the mood to follow it anyway because in case it works it'll lead me to Pedders' website.
What I would do if I were you is follow this link:
https://forums.nasioc.com/forums/showpost.php?p=18688737
because that will tell you what parts will fit any given car. I'd then go from there.
FWIW I'm using stock springs and Kayaba adjustable damper cartridges and have found them reliable. I own a bugeye.
Discussion Starter · #3 ·
Ah good to know, kyb adjustable looks like a good route. Basically trying to get the best bang for my buck, struts are shot and figured a may as well upgrade a touch from stock in the process. Do I need to put on new top mounts at the same time or can I just reuse the stock ones with the kyb struts?
1 - 3 of 3 Posts
