FS: Exedy Hyper Stage 4 - Twin Disc Clutch Kit - $1250
Exedy Hyper Stage 4 Twin Disc Clutch Kit
Part Number# FM022SD
Condition: New plates, resurfaced flywheel, new throwout bearing,
Never been used or installed, However has been Taken out of box as seen in photos below.
Applications: Can be used on multiple engine types: Mainly used for the EJ257 (SUBARU STi 04 - 11)
Exedy Site Description: For high-powered applications EXEDY offers Multi plate clutches. These are designed for hot street action as well as drag, road, and rally racing. All of our multi plate clutches come with a lightweight chromoly steel flywheel, and the famous purple anodized forged aluminum clutch cover. Depending on the application, both strap drive and lug drive models are available. All have T5001 cerametallic friction materials for extreme heat resistance. The multi plate clutches are rated up to 800+ foot pounds of torque at the flywheel. And come with spring damper or solid discs depending on the application.
Clutch Specs:
Number of Discs: Twin
Spring Damper Discs: Sprung Center Disc
Push / Pull: Pull Type
Disc Outer Diameter: 200mm
Spline Teeth / Major Diameter: 24T / 25.2 mm
Comes with everything seen in pic.
Price: $1250 (cash, money order, paypal)
Questions Contact: Dave (Five.Zero.Three) 740.9059 call/text
Or just PM me.....
Beaverton/Portland area,
Willing to ship or meet up with in reasonable distance...
Shipping economy USPS is around $30 give or take....
