1 - 20 of 24 Posts
I've been reading some threads on air filters but couldn't really figure out what the consensus is. Should I get a new drop in/panel filter, or just leave the stock one and change it every 10/15k miles..
As far as brands, I keep hearing K&Ns suck because the oil screws up the MAF and they dont filter very well..what other choices are there?
Thanks
I've used k&n's, stock filters and I now use a perrin filter. with the stock filter there wasn't as much intake noise(the intake silencer was removed). this leads me to believe that they don't flow as much. I could see through the k&n, so that was out. The Perrin was fairly cheap(around 30 bux) and is a very sturdy foam filter. Did I feel a difference from any filter? No. So choose one and be happy. :)
Subaru do a STi panel filter (pt no ST165464S000) and it's regarded over here to be one of the best filters you can get. :)
yeah i know theres not really performance gains..i was just looking for a little better sound...
anyone have a link to a good deal on the perrin filter?
thanks
As long as someone can convince me that stock Subaru filters aren't robbing me of more than 1 hp, I'll just stick with them. I'm not crazy about the idea of oil getting all over my MAF...
I've had stock, Perrin drop-in, and a Blitz SUS short ram.
Best sound - Blitz
Best look - Blitz
Best filter - Stock
Biggest oily mess - Perrin (this thing has more oil than Billy D Williams' old hair due).
What I am running now - stock
Discussion Starter #9
seems like the sound isn't worth getting an oily filter and risking damage to the maf...maybe i'll just stick w/ the stock one as well.
Is this true???
I just ordered this one like 2 days ago...now i'm not too sure if I want to put it in.
Have others had similar problems with the perrin drop in filter?
It is unlikely that the oil will damage the MAF sensor. If it gets oily it can be cleaned with non-chlorinated brake cleaner. While damage of the MAF is unlikely, oil on the MAF sensor will definitely foul the readings. I had my Perrin on there for a while w/ no problems, but I decided to take it out as I really didn't feel like making MAF cleaning standard maintenance and I wasn't seeing any power gains.
there's alot more cars on the road using MAF sensors than the wrx. alot of people use K&N type oil filters, if this was a major problem i think K&N would design something better.
i believe most peoples problems are due to over oiling or using those foam style filters.
Most people do over oil the filter. The trick to cleaning the filter is lightly oiling it in a nice consistent spread and then letting it sit overnight in a dry place with good airflow.
Probably true for the K&N or other fabric filters. The Perrin, on the otherhand, is foam and comes swimming in oil. If you decide to go with a panel filter I would stay away from that one.
Have used KN for 50 000miles. No problems. Just clean it once or twice a year, and don't use to much oil..
Discussion Starter #16
true...
If there is a common thought, its this: the oiled filters don't provide any improvements in air flow UNTIL you begin comparing equally dirty filters. Oiled filters flow much better when dirty than a paper filter. So, if you change your filter often, you'll be fine.
1 - 20 of 24 Posts
