1 - 8 of 8 Posts
i just installed a vf22 turbo, sti inj., utech, spark plugs, and a fuel pump. we took it out on a drive and it started to get real hot. ya i know that i lost some coolant when we took off the old turbo but i put some in the over flow tank but dont think its filling back up though that .please help very puzzled .
when you lose fluid you get air in the system. when you drive you pump the air out, and the level will go down, so then you need to add more fluid.
With the car cold, take off the radiator cap. Start the car and let it run through a heat cycle, air should bubble out the top then you should have got rid of it.
Yup, or you could be an idiot like me and drive it instead of just let it sit and hea cycle.
Discussion Starter #8
i think i got it . i filled it up and then started the car let it get hot while adding some (seen lots of bubbles) and then drove the car for about 20 miles or so the temp. didnt go up any more then before the swap. now its time to get it tuned and see what #s i get out of it now. thanks for all your hepl guys.
1 - 8 of 8 Posts
