Vendor
Transform the front end of your 2018-2019 Subaru WRX from drab stock to custom eye-catching look with new Grillcraft XE Series LED Black Powder Coated Stainless Steel Mesh Main Grille Kit! It will not only change the styling of your ride but also improve its light output thanks to the bright LED Rally-style lights.
Grillcraft® - 1-Pc XE Series LED Black Mesh Main Grille Kit at CARiD.com
Features:
- Includes Main Grille, 2 LED lamps and wiring harness
- Each light uses high-quality LEDs to produce over 1,000 Lumens of light with minimal power draw
- The signature woven mesh is manufactured from .092" diameter 304 stainless steel
- The XE Series lamp mounting system features patented mounts that allow for versatile light mounting and individual light adjustability
- Grille is CNC formed and contoured to fit perfectly on your vehicle
- Precision TIG welded mounting tabs assure your grille stays on your vehicle just as you installed
- Backed with an Industry Leading Lifetime Warranty.
View more GrillCraft Custom Grilles, Wire Mesh, Billet Aluminum at CARiD.com
Let your Subaru WRX have the look, that will make fellow enthusiasts turn heads with Grillcraft XE Series Grille on!​
