1 - 5 of 5 Posts
Does anyone know what fuse controls these or what other points to check? It's very odd they just stopped working all the sudden.
The power windows are protected by a circuit breaker, not a fuse, so they should'nt just quit unless the power window relay went bad. There is a stack of relays next to the fuse box under the dash. The power window relay is the 4th one from the top. Hope this helps....
Joe
Sorry about that......:eek: It's the fuse box behind the coin tray, top row, 4th fuse over from the left, 20A
Joe
hokieitr, Check your cigarette lighter to see if it still works. They use the same relay. If that isn't the problem, pull up the center console and see if the power mirror connector has somehow come loose. Mine did the same thing and it was a loose connector.
1 - 5 of 5 Posts
