1 - 2 of 2 Posts
So i get my oil changed on my bug-eye, 2003 wrx, 2.0 t (226,000 miles) silver, on a Friday... the fallowing Friday night i check the oil... about 1/4 inch of oil was showing i had to add 1quart and a half, i drive about 600 miles a week just to work and home. It has a small seeping at the oil pump is what the Subaru tech said when i took it in on the recall notice! i just keep adding! and then get it changed every three times i add a quart ! wtf is going on its like bottle feeding an baby!
It's 1 qt between marks. Was your level below the LOW mark then?
What recall notice?
What do you mean?
It's either a leak or you're using oil, or likely both from what you've said. Find the leak, see if it makes $en$e to fix it or not. If not, keep topping off. You can try other oils to see if your consumption will be reduced.
1 - 2 of 2 Posts
