1 - 3 of 3 Posts
I had asked a week or so ago about wheels, and had come to the decision of going with a set of Enkei RPM2 18x7.50 with 225/40/R18 tires on them. (+50mm BS)
My question now is, i was looking at possibly getting some stiffer springs, and had come across the Eibach Pro Kit. (http://www.jscspeed.com/wrx/suspension/eibach_ls.htm).
I noticed it drops it 1.3" in the front and 1" in the rear. I was curious if this is going to cause any rubbing issues were i to install these wheels/springs.
Moderating on the run!
The Eibach's are pretty mild in the drop dept, so shouldn't be an issue- especially w/ a sedan. Wagon could possibly run into issues (but still think you'd be OK).
Big Sky
Hey thanks for the info, i just realized i suck at life and forgot to mention it would be on an 05' WRX Sedan.
Sorry to bother again, but i just thought about the camber. Should i purchase a set of adjustable caster/camber plates?
1 - 3 of 3 Posts
