1 - 2 of 2 Posts
Hi!
Has anyone tryed to install both the pressure and temperature sender with the
relocation kit for the subaru on the FRONT galley plug under the alternator?
I know the location is good for the pressure but is it for the temperature also? I know the reading wouldnt be 100% accurate, but if it misses for a 10 degrees it wont bother me that much, becouse i am not the wildest of the drivers:tongue:
P.S.
the car is a wrx 2002
If you want to install the gauges in the same location, use an oil filter sandwich adapter. Otherwise, install pressure in the galley plug behind the alternator, and temperature in the galley plug under the I/C.
1 - 2 of 2 Posts
