1 - 10 of 10 Posts
Hey guys ive been getting some pretty bad rev hang when up shifting (esp. at WOT). So today i decided i would take it off and cleaning it to get some hand on experience and see if that would help. Got some TB cleaner from autozone, and needless to say there was a huge build up behind the butterfly valve, it worked pretty well, havent installed it yet. I figured id go ahead and remove the intercooler and clean it as well. When i took off the y-pipe i could see a streak of oil residue in the right flange going down the curve. Im concerned this may be a turbo leak. I called 2 shops 1 said the same thing after i reported the symptoms, the other (mor familiar with boosted cars) said it was normal. What do you guys think?
Super Moderator
The GS AOS has worked very well for me.
So cleaning the TB made a huge difference. The rmps drop much much quicker than before now, but im still getting a slight pause before they begin to drop. Any ideas? Lmk if you need more info
Are you sure that pause wasn't there before? My car always seemed to have a slight delay and I thought it may be programmed in. I kind of like when the rpm hang a tiny bit if you are driving very spiritedly but not banging gears.
Gold Member
Gold Member
I'll be calling GS today to see what hoses these are.
Gold Member
They said the hoses are made by Gates, but I can't find them anywhere! Ugh. Is it really that hard to find 1/2" and 3/4" clear hose that is suitable for fuel/oil use?
1 - 10 of 10 Posts
