1 - 14 of 14 Posts
So I'm having issues with my wrx in the way of oil pressure. My motor is a brand new ej22 with 1500 miles on it... The pressure is supposed to sit at 14-12 psi at an idle. For the most part thats where mine sits. But when I'm doing some sporty driving, it drops to like 10 psi. But the oil has to be nice and hot.. I feel as though the oil is breaking down prematurely I changed it like1000 miles ago and I used 5w30 and was informed that was a little thin.. Any ideas? Or do I even have a problem at all?
Pro Manscaper
5w-30 is what Subaru uses from the factory...but when you say sporty driving, you mean as taking some twisties and curves?
If you're taking some turns like that, g-forces will cause oil in the block to shift some, possibly taking it away from the pressure sender. Seems like it'd be normal to me.
It can't slosh away from the pressure sensor, but it can move away from the oil pickup resulting in momentary oil starvation.
UOA will help give you insight about the oil. Look into that.
Where are you monitoring pressure from?
The company that made the motor informed me to put 10 w 40 in but I know Subaru recommends 5 w 30 but I've never seen it drop below 10 psi and that's after I get off thr freeway for like 50 miles at like 100 mph or if I'm doing speed runs down my road.. But from what I'm seeing you guys say it doesn't seem to be a problem
Discussion Starter #7
I have a gauge running from where the oil pressure sensor used to be on top of the block
Is there a galley behind the alternator on the EJ22?
Chas said:
Yeah that's exactly where I'm coming from
Alright. What gauge are you using?
Chas said:
Some old ass sun pro that doesn't use a sensor oil goes right to the gauge
I would check with another gauge to verify your current findings.
That's always a good idea just to know your gauge is reading accurately. Although in my experience mechanical gauges are generally more reliable than electronic ones using a sending unit. The only problem here is the potential for oil to leak from the gauge into the cabin and create a mess.. but whatevs, because racecar!
Discussion Starter #14
lmao yes racecar! thanks guys for the help. whats a good website to find cool subie add ons
1 - 14 of 14 Posts
