1 - 8 of 8 Posts
Ok, So I have an Autometer Oil Pressure gauge. The plug that you take out (where you want to intall the the correct adapter) seems to have a non standard thread pattern. It is not 3/8" NPT or 1/2" NPT....I will post some pictures and then ask a question.....
First pic is on the plug still screwed down.
Discussion Starter · #2 ·
Here is just the plug.....
Discussion Starter · #3 · (Edited)
And here is the pic with the adapter I need. What kind of bushing is that???? It is 1/4" NPT on the female, I know that because that is what the sender is, but what is the male end (the end that is the same as the stock plug??? Do I have to tap the stock plug??
The adapter has the red box around it. This picture is from scoobymods, so I know the adapter exists, I just need to know what size it is, and where to get it. I can not get it at the hardware store or at the autoparts store.
Thanks...
It's a British Thread
Sorry, don't recall the size, but it is some goofy (to me) British(?) thread, according to some postings on the old i-club. Try a search on nabisco for oil sender bushing. They listed the part number from Subaru. I will check tonight when i get home. I believe I saved the info on my hard drive.
Curtis
Discussion Starter · #5 ·
Ok, so I think I have figured it out. The stock plug is BSPT, either 1/2" or 3/8", and the sender is 1/4" NPT. I just need to know exactly what that plug is so I can order the correct adapter from McMaster Carr.
Thanks to whoever knows.
-joe
I just did an oil pressure sender install (and other gauges with Pace's help, THANKS PACE!!) this weekend. The adapter is a Subaru part, PN 11024AA210. See http://forums.nasioc.com/forums/showthread.php?s=&threadid=332169&highlight=oil+pressure+sender for details. It has an 1/8" NPT (National Pipe Thread) female thread. I know you said your sender is 1/4". But, are you aware that an 1/8" pipe thread is actually about 1/4" diameter? The 1/8" refers to the ID of standard pipe, not the thread size. If your sender has the same thread size as the one in the picture, it is 1/8" and the Subaru part should work.
The sender I had would not fit and I had to tap the adapter out further (NPT's are tapered and the two parts weren't a match stock). Only took my dealer one day to get the part. Good luck.
Leo
Discussion Starter · #7 ·
Thanks, I got everything sorted out.
I did mean 1/8" and not 1/4, I had looked at so many adapters and bushings that I was starting to confuse myself. It turns out that the Subaru part has m18 x 1.5 male and 1/8" bspt female, and I ordered the Autometer 1/8 bspt to 1/8 npt adapter, so it looks like I am all set to go.
-joe
is that electrical or mechanical oil pressure?
i have the same problem with the adapter
thanks
1 - 8 of 8 Posts
