1 - 6 of 6 Posts
Hey! I drive an 09 wrx sedan and was wondering if there are known common leak spots in the ej25. It looks like it’s coming straight from the block, but there’s no way of telling unless I pulled everything off, and I don’t have the things to do that. The leak has picked up a lot, and I’m really trying to avoid doing a full refresh. Would appreciate some advice on this, and also I’m tired of buying oil lol.
Super Moderator
Valve covet gaskets, rear main seal, turbo seals, oil cooler seal.
Yeah, they leak.
Super Moderator
Explain how you came to that conclusion.
That's not what an AOS does.
Super Moderator
That is completely unrelated to your problem and should be ignored u tilnyou find where your oil leak is and fix it.
1 - 6 of 6 Posts
