1 - 20 of 29 Posts
Moderating YOU, before you had your Subaru!
PANNING Tips
Panning Tips
A few tips for shooting moving cars.
SHUTTER SPEEDS
Anything under 1/250 will generally give decent blur in the wheels and still provide sharpness in the subject. The slower the shutter speed the more blur, naturally.
SELECTABLE FOCUS POINTS
IF your camera has selectable focus points, choose one that is either left or right of center, depending on the direction of travel. Place the focus point over the front of the vehicle (the front wheel or grill area works well). When combined with a slow shutter speed (1/125 or less) you will realize a fading sharpness from the front of your subject to the rear, e.g., the front of the car in focus with the rest of the car becoming progressively blurred; very cool effect. Works well with fill-flash, also.
EXAMPLE:
FOLLOW THROUGH
Don't stop moving the camera after squeezing the shutter release. Continue to follow the path of your subject. This will ensure that you don't cause blurring or an out of focus condition because you stopped moving the camera while the shutter was still open. Also, the more fluid your panning movements are the better your results will be.
COMPOSITION
Avoid placing your subject (car) in the center of the frame. Have some
lead-in area to give the impression that the car is coming into the frame, or exiting. Remember the 'Rule of Thirds'.
IMAGE STABILIZATION
If you use Image Stabilization lenses with multi-stage IS, such as the Canon 70-200 2.8 L IS, set the lens to IS position 2. IS position 2 is designed for panning.
DUST SPOTS
Shooting at slow shutter speeds in bright day light will cause you to shoot at smaller apertures (F16+) in order to achieve 1/200 and less. This will acentuate any dust that is on your sensor (DSLR) that you otherwise may not have realized shooting at wider apertures. This generally becomes painfully obvious as dust spots in your images when shooting at F22+. Learn how to clean your sensor. There are tutorials on the web for doing this at a minimal cost. I use Pec Pads and Eclipse fluid on homemade cut-down spatula handles and a Rocket bulb blower. DO NOT USE COMPRESSED AIR!
Shoot multiple frames. Shooting at slow shutter speeds are typically low-return as far as keepers go. At least as far as others are concerned, that is. What I like, someone else may not. Since my goal is to sell photos to racers, well, I have to please their taste without compromising mine. So, shoot plenty at varying shutter speeds from 1/250 to 1/15 and wiegh the amount of background blur against the lack of sharpness in your subject and find what works best for you.
I have many samples at www.pbase.com/cvbjr . Just look in any of my galleries of races - road racing, drag racing, STi, etc. Many of the photos have the EXIF data available so you can see the camera settings I used to make the shot.
Peace,
Curtis
I have a quick question about my rebel xt.
do i have a setting on it that will allow me to take a picture and accent one color and the rest of the picture be in black and white (or some sort of muted tones) to help that one color stand out??
i know some cameras have this setting, but have not found the official term to look it up on mine.
I just happened to be reading through my manual last night in search of this. The only thing I could come across were Filtering effects and Toning effects. BUT these both are only used during black and white shooting. I haven't tried messing with any of these yet, but it sounds like you want Toning effects. Should be page 66 of your manual.
Probably not. image>ajustments>hue/saturation in photoshop, select a color at the top and desaturate, desaturate all the colors 1 by 1 except the color you want. Or selective color under image>ajustments works. play around its pretty easy. Or use a selection tool on the area you want in color, and desaturate the rest.
just goofed off with it a little. it is an obvious work in progress.
a friend of mine says they have a camera that somehow has a setting for something along these lines. I should hear from them tomorrow as to how theirs works....or if it is a program that they have to physically do it.
From start to finish.
Lesson 1
YouTube - Lesson 1
Lesson 2
YouTube - Lesson 2
Lesson 3
YouTube - Lesson 3
Lesson 4
YouTube - Lesson 4
Lesson 5
YouTube - Lesson 5
Lesson 6
YouTube - Lesson 6
Lesson 7
YouTube - Lesson 7
Lesson 8
YouTube - Lesson 8
Lesson 9
YouTube - Lesson 9
Lesson 10
YouTube - Lesson 10
Lesson 11
YouTube - Lesson 11
Lesson 12
YouTube - LEsson 12
Lesson 13
YouTube - Lesson 13
Lesson 14
YouTube - Lesson 14
Lesson 15
YouTube - Lesson 15
Lesson 16
YouTube - Lesson 16
Lesson 17
YouTube - Lesson 17
Lesson 18
http://www.youtube.com/watch?v=2cLesson 21
Lesson 19
YouTube - Lesson 19
Lesson 20
YouTube - Lesson 20
Lesson 21
YouTube - Lesson 21
Lesson 22
YouTube - Lesson 22
Lesson 23
YouTube - Lesson 23
Lesson 24
YouTube - Lesson 24
Lesson 25
YouTube - Lesson 25
Lesson 26
YouTube - Lesson 26
Lesson 27
YouTube - Lesson 27
Lesson 28
YouTube - Lesson 28
Lesson 29
YouTube - Lesson 29
Lesson 30
http://www.youtube.com/watch?v=RTPKVQsFhHk1PAT8QXY0
Lesson 31
YouTube - Lesson 31
Lesson 32
YouTube - Lesson 32
Lesson 33
YouTube - Lesson 32
Lesson 34
YouTube - Lesson 34
Lesson 35
YouTube - Lesson 35
Lesson 36
YouTube - Lesson 36
Lesson 37
YouTube - Lesson 37
Lesson 38
YouTube - Lesson 38
Lesson 39
YouTube - Lesson 39
Lesson 40
YouTube - Lesson 40
Lesson 41
YouTube - Lesson 41
Lesson 42
YouTube - Lesson 42
Lesson 43
YouTube - Lesson 43
Lesson 44
YouTube - Lesson 44
Lesson 45
YouTube - Lesson 45
Lesson 46
YouTube - Lesson 46
Lesson 47
YouTube - Lesson 47
Lesson 48
YouTube - Lesson 48
Lesson 49
YouTube - Lesson 49
Lesson 50
YouTube - Lesson 50
Lesson 51
YouTube - Lesson 51
Lesson 52
YouTube - Lesson 52
Lesson 53
YouTube - Lesson 53
Lesson 54
YouTube - Lesson 54
Lesson 55
YouTube - Lesson 55
Lesson 56
YouTube - Lesson 56
Lesson 57
YouTube - Lesson 57
Lesson 58
YouTube - Lesson 58
Lesson 59
YouTube - Lesson 59
Lesson 60
YouTube - Lesson 60
Lesson 61
YouTube - Lesson 61
Lesson 62
YouTube - Lesson 62
Lesson 63
YouTube - Lesson 63
Lesson 64
YouTube - Lesson 64
Lesson 65
YouTube - Lesson 65
Lesson 66
YouTube - Lesson 66
Lesson 67
YouTube - Lesson 67
Lesson 68
YouTube - Lesson 68
Lesson 69
YouTube - Lesson 69
Lesson 70
YouTube - Lesson 70
Lesson 71
YouTube - Lesson 71
Lesson 72
YouTube - Lesson 72
Lesson 73
YouTube - Lesson 73
Geriatric Ginger Mod
1 - 20 of 29 Posts
