1 - 20 of 21 Posts
All of the sudden cd player seems to be non functional all I have is radio, i press cd; nothing, load; nothing, eject; nothing. Anyone ever have this problem? I let my father drive one time and I think that's when it happened. Anyway does anyone have any ideas of what could be wrong? I guess it would be under warranty but it just sucks not being able to listen to real music.
Mine did the exact same thing. Just take it in for a warranty repair.
Or get a bigger hammer.
Pain in the...
Wasn't there a fix for this? I think someone posted that they unplugged the radio for a certain amount of time, then held the eject button to eject all the CD's and it worked after that.
Ummmmmm
With the placement of the drink holder it is a wonder that anyone has a working radio if they use it!!!!! Who thought it would be a good idea to put the drink holder above the radio unit? Condensation runs right onto the radio and quick stops, we you can only imagine!!!
Re: Ummmmmm
audi/volkswagon does the same thing :mad:
*hellooo? are you engineers drinking in there?*
My CD player took a **** all of a sudden about 2 days ago and nothing worked. No sound, no display, no button responce. I took the thing out and pulled the tiny lever on a spring in the back, which i hoped un-jammed the thing. I plugged it back in and it spit out all 6 discs and has been fine since then.
Discussion Starter · #13 ·
If you have the OEM boost gauge, look at the manual that came wit hit :) Very good instructions on how to remove the cd player. It's pretty simple too
xylem007 said:
any place that has good head unit removal instructions?
Pop the cupholder out
Remove the two screws holding it in
Pull the center vent piece out and unplug the hazard light harness
Pull the radio/climate control trim piece off (yank hard)
Remove the 6 screws around the head unit...3 on each side
Easy! :D
w00t
i thought i would break it but i pulled progressively harder till it came loose... No dmg.. ;o)
Discussion Starter · #16 ·
Wow, I should be a car radio thief got it out and in under 10 mins hehe
anyway no dice. I tried plugging it in and out and it still doesn't work all i accomplished was resetting my preset radio stations. Looks like i will have to warranty it.
Get it down to 60 secs and you can be a theif i think.
I'm going to have to warranty mine too.. I'll post when i know what it was.
Did you push the spring loaded tab I spoke of in an earlier post? If not then...i dont know, way to read the thread...
Discussion Starter · #19 ·
I did the spring thing, I got the discs out but i had to repeat the process 6 times. Now I can't put cd's in and when i press cd it just makes the clikc sound as if its trying to load one or get ready to and just can't
i tried the spring thing...
It wouldn't budge. I used a jewelers screw driver and couldn't move any of the levers that had springs on them.
1 - 20 of 21 Posts
