1 - 20 of 26 Posts
do you think it's safe to use this thing?
do i need to buy any other part than this thing?
Yes, it's safe, and thats all you would need.
Not sure if the sprayer thing would be too big for the top mount though, might hit the hood.
i've seen pics, and it fits fine....there's room because of the hoodscoop. i want one of these kits, they look sweet :)
If it'll fit on the TXS TMIC, it'll fit on our stocker. It's a nice piece :D Does anyone have any info on how to operate one of these things? Is it like a direct port wet nitrous system where you spray it as you go, or do you cool your IC before take off?
Discussion Starter · #6 ·
hey, what do i need to spray a smoke from the hood?
is that called purge kit?
Discussion Starter · #8 ·
do you think I need the purge kit?
Can I use it?
No you wouldnt need a purge kit because in actuality, this IS a purge type deal....It just sprays the nitrous onto the IC where a purge kit sprays it into the air...same differnce this just targets an area
Can I use it?
If you're trying to do the whole 2 Fast 2 Furious bit, like that Skyline, then you'd have to get some extra lines and extend them to where you want the nitrous to purge from. Not sure if there's a redirection kit, but I'm sure you could make one.
Discussion Starter · #11 ·
hey, u read my mind! LOL
r u a mind reader?
hey
FYI--they do NOT recomend spraying nitrous on the intercooler. The kit is made by a company that makes nitrous systems, but they recomend using carbon dioxide for safety. I think their nitrous bottles in their kits usually get filled with nitrous/fuel...and that would be worse.
Discussion Starter · #14 ·
someone also said that it's dangerous to have N20 as the sprayer
but i'm not sure if that's true though
so anyone actually has it on the car right now?
Discussion Starter · #16 ·
so the gas inside the bottle is not N2O but CO2?
Re: hey
hippy78 said:
yes sir. it has the same cooling effect without the possibility of combustion.
N20 cant catch fire. Its an oxidizer. Not compustable, it just lowers the temp of the intake charge.
hey
so if there were a fire, it would make the fire hotter.......On another note, I was wonderin why no intercoolers come freon cooled. Would it not work well, or would it be dangerous? I dunno, but I figured someone musta thought of it b4....
Re: hey
freon sounds sweet! Come to think of it, a few years ago, I was toying with an idea of somehow plumbing the AC system in with intercooler, to use that to cool it. Dosent the 03 SVT Lightning have something like this?
1 - 20 of 26 Posts
