P0420 is Catalyst System Efficiency Below Threshold (Bank 1.) I have looked at many past threads on this but wanted to share my experience with this DTC which recently caused my CEL to come on. My 2015 is almost exactly 2 years old with 36,500 miles and engine/exhaust/fuel system is all stock. I do not even have an AP. All of a sudden one day after I left from the gas station the CEL came on. The car was running great, the same as always. Next day I go to Autozone to have them tell me what code is set. There is only 1 and it is P0420.
Then I go to the dealer and they confirm the code and schedule me an appointment for a full diagnosis (appointment is next week.) Being the paranoid, un-trusting type, I go home and over the weekend check a few things in the troubleshooting sequence for this code from the service manual. I can't check everything because I don't have a datalogging device yet for the O2 sensor but I did check for visual damage and a couple resistance checks of the sensor harness wires. I found nothing abnormal. But I did, of course, disconnect the connector at the 02 sensor to do the resistance checks. I put things back together and now have driven several drive cycles and the CEL is NOT on any more. ?????
All I did that would affect anything is disconnect/reconnect the rear 02 sensor connector. One of the troubleshooting steps says to look for water in the connector. I found none. I am not sure what to make of this.
Oh, and one final interesting thing -- at first i could not get the connector apart so I thought I'd try to take off the small bracket which holds the body side of the connector in place so I could get a better grip on it. There is one small bolt going through the bracket into the engine valve cover (or head, I forget.) After I got the bolt out I realized it won't work because this bracket is also welded to the coolant line to the oil filter housing. But, anyway, as soon as I cracked the bolt loose I see a "foaming" ring of liquid stuff form just under the bolt head! First thought is this bolt was some sort of drain plug but then sanity took hold and I realized it couldn't be since it just held a bracket in place on the head/valve cover. I removed the bolt and smelled and felt the liquid. I could not tell what it was; it was not water and it felt ever so slightly oily.
The only conclusion I could come to was some sort of thread-locker or anti-seize. But it did not look like any thread-locker I had seen before and I am not even used to this being on such bolts and furthermore, why would it "foam up" when the bolt torque was released. Not sure how this could affect the 02 sensor connector but I just thought it interesting and it was somewhat just above the connector. So I am not sure what I am saying here, if I am saying anything at all, (Iron Man) except maybe it appears just cycling a connector can have a real effect on a sensor working. At least it appears so far, that is all it took to fix this issue. In the next couple days if the light does not come back on I will cancel my appointment with the dealer; it would have cost me $70 for the diagnosis. :dontknow:
