missing tons of data here like boost pressure , timing , supporting mods and fuel type
Talk to your tuner
Talk to your tuner
Out of pure curiosity, did you have a pro tune on this? (I assume yes because of the 2 differences in modes)As of right now its on 15psi @ Sport(300hp) and 18 @ Sport# (367hp)
Mods:
Blouch Performance 20g-xtr turbo
Grimmspeed tmic
MXP headers and uppipe
Invidia catless downpipie
Cobb sf ram intake
Cobb 1000cc injectors
Cobb ebcs
Cobb access port v2
DW fuel pump
GFB fuel pressure regulator kit
IAG aos
SPT strut tower brace
SPT Lower chasis brace
SPT short throw shifter
SPT Group-N trans and motor mounts
SPT Group-N pitch stopper
Id like 400 to the wheels on 93.
You have a larger turbine wheel than the traditional "20G" turbos, and the better compressor wheel, but I still don't think it's going to be enough for 400whp on pump fuel. 20G turbos were always a "350whp" setup, give or take. I'm not sure how much of a limitation your stock block was on your ~365whp tune; I'd expect in the 370-380whp range for that turbo on 93. The BEST estimate for what you will likely see on that setup is going to come from the person calibrating the vehicle; they know their dyno and how the parts used typically react.MainFrame said:Not gonna happen.. you would probably get close on e85, but not on 93 unless it's a really high reading dyno. Not sure what you mean by pushing the turbo "too hard".. it simply can't move enough air to make that kind of power.
