1 - 2 of 2 Posts
Hey Everyone, could use some help here. I have a 2010 WRX with an AEM cold air intake, NVIDIA 3" catback and 3" grimmspeed catted downpipe. Currently running the 93octane LWG Stage 2 Cobb AP tune. I went with the LWG tune because when I did the standard stage 2 tune, I was boosting over 19psi. My car had been running fine, however I just noticed that I am not getting the boost that I should be. Since I have noticed it, I haven't really pushed my car but in gears 2-4 I'm not getting over 2psi boost. My TD Boost Error is showing values from -11 to +22, which I know can't be good. I checked my AF learning 1A, 1B, 1C and they are all under +/- 5% which I read is a good sign. I have had some issues with BCS, so maybe this is the issue? I read that sometimes the BCS can get stuck in the open/closed position, but I am not sure how to check this.
Any opinions and feedback would greatly appreciated. I don't want to bring my car just yet in case this is an easy fix.
Super Moderator
I would imagine if you had a boost leak that big you would hear it. The boost control solenoid is also a viable option.
I can't speak to the learning because mine was always around 1%.
1 - 2 of 2 Posts
