1 - 16 of 16 Posts
taken from August/September issue.
They start off with the 'engine only'
1: ECU
2: Uppipe
3: Exhaust axel back
4: CAI or Open Air element
5: Headers
6: Pulley
7: Boost controller
8: improved top-intercooler
9: "Compressor discharge tube"
10: BOV (expecting a boost increase)
11: vf22 turbo
12: fuel rail and pump
13: self programmed ECU and boost controllers
14: heavy turbo, sr50 or t67 custom
15: Front mount intercooler (with a turbo from 14)
16: gutting the intake tract of its tumbler plate
17:head work (port and polish)
18: stroker kit.
Thoughts? opnions?
i'm sure they meant to buy such things in an 'order of magnitude' sort of thing.
I'm surprised, I thought alot more people would have something to say over this.
it was an OK article.
the reason it looks like they have you replace IC or turbo twice is b/c it had all that above split into 3 levels and if you went with highest you went with that turbo/IC and then everything else below excluding smaller IC/turbo.
they coulda lost the headers and the intakes but otherwise it was ok i guess...
thats a very dumbed down article on modding though. so thats kinda what you get.
youll learn more hanging around here than in 7 pages of a mag.
eitehr way though they talked about the rex throughout the mag with really high regards which was cool
I got this mag sitting on my table right now. I haven't got that far into it yet, but have scanned through it.
I agree with qoncept. Take out the intake and you have a pretty good guide to go with.
From what I've learned from this board and other sources:
1: Definately.
2: An aftermarket uppipe doesn't help unless it is catless or you are planning bigger mods down the road. For a light tune or mostly stock car, a gutten uppipe is perfect.
3: Just an axel back wouldn't help too much. The farther from the engine a restriction is, the less impact on eprformance it will have. Best to do a TBE. THough, looking through the list, unless they are counting the DP and MP in #9, they don't have you replacing them at any point.
4: Unless you're going with a bigger turbo and FMIC, a CAI can hurt performance by messing with your MAF readings. A good panel filter works just as well.
5: Reading up on COBB and other sources, Headers aren't a big problem with the WRX until you make serious power. Best to hold off on these.
6: Big controversy over these. I'd say don't change them if this is a daily driver.
7: Most people here don't seem to think a MBC is a good idea. An EBC or good ECU seem to be the preferred choice.
8: This only has a minimal effect with the stock turbo. If you are plannin on a larger turbo, then a better IC is good. But whether to go TMIC or FMIC should be decided at this point.
9: From what I've read a dump tube is not a good idea for overall performance. Instead a cast bellmouth is the optimal solution.
10: Only if you're upgrading your turbo.
11: the vf22 is good for Drag racing, but the vf34 is better for daily driven/ AUto-X cars.
12: I've never heard anyone here refer to the fuel rails. I don't even know if the WRX has rails precisely. But Upgraded Injectors and pump should go in before or with a bigger turbo.
13: Should have been done at #7 if you were planning.
14: Should have been done at #11 if you were planning.
15: Should have been done at #8 if you were planning.
16: I have no idea. Never heard of this, have no idea of what it would improve/impact.
17: From what I've read, The heads aren't as big of a deal as a stronger bottom end.
18: I'd swap this with #17.
Essentially, good planning will save a lot fo time, money and effort. Yes, some of the mods will be overkill at first if your goal is a Monster WRX, but they'll still do the job. Plus, some of their specifics aren't good choices for those who only want a light to medium tune (CAI, Headers, etc).
Just my $.02
Perhaps I'm just missing it, but is there any mention of upgraded injectors? :confused:
The fuel rail is debatable as well.
If you do all that work with no brake/suspension/tires your chances of killing yourself increase 10 fold.
I personally ignore what magazines have to say about upgrading our particular car. They don't even mention the injector upgrade that's necessary before any proper turbo upgrade. (disclaimer: Yes, you can run a larger turbo on low low boost with stock injectors, but it's not worth the trouble)
The fuel rail is a different thing from the injectors.
Information from this site (and Nasioc) is far more valuable than what you'll find in a mass market publication. IMO...
Exactly!
KABLAM
there goes your trans. ;)
16. i think is referring to the tumbler delete mod.
what's the point of an MBC if your'e doing an ecu reflash in #1?
axleback is useless, i'd rather go with a catless downpipe first. it will help spool up.
pulley is a waste of money. i have one and all it did was eat up some voltage.
1 - 16 of 16 Posts
