1 - 6 of 6 Posts
My '02 wrx has 75,000 miles, just changed the plugs and still has no high-end power. It starts to bog down at about 5000 rpms and has no speed build up from that point, in all gears. I'll admit I haven't been very good about the cool down time on it, could it be the turbo ? Please any suggestions.
the stock turbo normally drops off in the top end. its too small. but what your saying sounds a bit more severe, might want to get it checked out.
Stop drivin it now..and bring it to a dealer and get a compression test done. Trust me.
No speed build up?? Something is def wrong..
Boost should be dropping if you run a mbc, but you will def. have speed build up...
I agree. Boost builds...compression leaks...engine go boom
1 - 6 of 6 Posts
