This is my 05 STi, I have had it since day 1. It has been a great 5 years but I think Im going to head into the boat world or the DSM world, so I need a change of pace. Im asking $28,000 OBO Why so much you ask? Well minus the gigantic list of mods, it only has 66,000 miles on the body, less than 2000 miles on the BRAND NEW TRANSMISSION (yes the $6000 transmission from subaru, not a rebuilt one), the motor (which is built for over 900hp easy) has only 17,000 or so miles on it, the rotors and pads were just replaced about 3k ago, i just recharged the a/c, ball joints were just replaced about 2k ago, it comes with an entire set of winter wheels (blizzak lm-25s on stock rims used for 3 seasons), custom car cover, extra walbro 255lph, and some other goodies. I HAVE THE TITLE, this car is paid off. No accidents, although it was hit while parked my senior year of high school a few times so i had the front bumper replaced. I have all of that paper work too. I also have receipts for just about everything.
Contact info:Anthony
[email protected]
PM
Here is the mod list:
Bolt-ons: Myself
Engine:precision Tuning
Tuning: ICS Performance
The bad:
slight discoloration on passenger seat as indicated by pictures
slight drivers side wheels scuffed as indicated by pictures
slight spider crack in front bumper, as indicated by picture(misjudged a driveway)
front floor mats are really dark, not blue anymore
Is it the cleanest looking STi around? Highly doubt it, but it could be. Am I lazy? No, Do I have time anymore? No.
Engine:
EJ257
Classified custom sleeves (150mm)
Custom Honing and decking
Manley 100mm bore pistons
Manley I rods
ACL Main and Rod bearings
Cosworth 278/274 cams
ARP head studs/block bolts
Custom TGV deletes
Polished, Balanced, knife-edged crankshaft
Port and Polished Heads
Manley Springs,Retainers,Valves
.5mm oversize valves
Cometic Metal Headgaskets
Crinkle Red colored block (no crinkle)
Black valve covers
NGK 1 step colders
Walbro 255LPH
Aquamist HSF-5 1mm jet, .9mm jet, 90/10 meth/water
AR Fab Harmonic Balancer
Custom Intake
Tial Bov 50mm
Tial EWG 44mm
Perrin rotated 35r .82
Perrin Signature Series FMIC
AEM Speed Density
Power Enterprise 850cc injectors (flowed and cleaned)
Peterson Fluid Systems Catch can
Apexi-gt spec catback
Kartboy rear diff. bushings
hallman pro rx mbc
modified perrin rotated dp
Electronics:
Sony headunit
NGK AFX wideband
Blitz DC II Turbo Timer
AEM engine management
Stewart Warner Gauges (boost 30-40, EGT)
Aquamist DDS3V8 red gauge
led dome light
Transmission:
Updated 05 Transmisson
Exedy Twin Disc Clutch
Exedy lightweight flywheel (14lbs. Vs. 19lbs.)
Front and rear shifter bushings (kartboy)
Brakes:
Hawk HPS pads
Technafit SS braided lines
Powerslot Rotors
Interior:
Schroth rally4e ASM racing harnesses
3 gallon Spec-c meth tank mounted in trunk
Exterior:
Debaged Trunk except wrximpreza
Grill mod
STi valve stem caps
Custom license plate mount
Cleared out headlights with halos
