New Toy
484 Views 10 Replies 4 Participants Last post by  Doc2022
Dark Matter DM-2 Shifter .
Musical instrument accessory Wood Musical instrument Electronic instrument Audio equipment
See less See more
  • Like
Reactions: 1
1 - 11 of 11 Posts
Looks interesting! Tell us more.
  • Like
Reactions: 1
Here’s a YouTube video
Installation tomorrow at Browns Subaru Performance
Gainesville Florida
You can now replace the ENTIRE OEM shifting assembly in the 2015+ WRX and convert over to linkage shifting with the DM-2. This shifter offers the Ultimate Shifting Experience for you and your WRX, further connecting you to your car.
Engineered from the ground up, the DM-2 has gone through rigorous testing and development by Dark MatterX to bring you the most direct and responsive shifting.
-CHASSIS MOUNTED FOUNDATION
The 6061 billet aluminum foundation is secured to the chassis using 304 stainless steel mounting brackets, whereas OEM shifter mounts to the vehicle using an entirely plastic housing.
-BILLET U-JOINT PIVOT
OEM WRX shifters use a plastic cup full of grease to pivot the shifter from gear to gear. The DM-2 has a billet steel u-joint that is pre-loaded onto four, ENDURO MAX ball bearings for durability and directness.
-CABLE DELTE
The DM-2 uses steel linkage with chromoly steel, PTFE lined rod ends that connect the shifter to the transmission shift plate. Our linkage allows the transmission to perform pitching and rolling movements for stress free shifting in corners and hard acceleration.
-SELF CENETRING MECHANISM
Our proprietary self-centering mechanism uses billet aluminum components, stainless steel detents, a torsion spring, and an ENDURO MAX radial bearing for the most precise movements. Our twin detents are loaded against a CNC machined, self-lubricating surface to give a crisp "home" for the shifter when centering itself in neutral. The spring pressure has been increased compared to the OEM feel to give the user a firmer shift when moving the shifter out of center.
-TOOL FREE SHIFT HEIGHT ADJUSTMENT
Adjusting the height of the DM-2 does not require ANY tools or the disassembly of your interior that other solutions require. Simply rotate your billet aluminum leather boot collar for over an inch of relative height adjustment. This easy adjustment can provide both a change in throw and a change in the drivers required, "Force" needed to shift. You will find that increasing the distance of the shift height will make it easier to shift, and vice versa, because of the relationship between "Force", "Distance", and "Work".
See less See more
Shifter at the Speed Shop Today ..
  • Like
Reactions: 1
Installed and picked up today..Quite nice !
I'm curious to hear reviews.
I've used a similar shifter in a friend's race car once. It was... Interesting.
  • Like
Reactions: 1
So far so good, I drove it about 80 miles today from the speed shop. A little tight but crisp.
Deletes the wires and mounts direct to the transmission. I’m happy with it, no more shifter slop .
This looks like it belongs in a sex dungeon.
  • Like
Reactions: 2
Yours perhaps ?
You ever been in the Service Zax ..?
1 - 11 of 11 Posts
