1 - 9 of 9 Posts
· Registered
So I bought a bug eye always wanted one it’s mostly stock but it has a few issues it’s hard af to put into 1st gear at any point, doesn’t matter if the cars on or off, that’s problem one problem to. I think the cats are clogged because it’s super quiet and it’s already had a muffler delete and after it gets up to operating temperature it wants to cut off on you I want to do a pardon few mods to it if there’s anyone who could help source parts I could use the help
· A dashingly handsome oversized Guinea Pig
You sound like you've got multiple thousands of dollars in potential problems before you even consider modifications.
The shifting problem could be a few things. Clutch related or shifting linkage related. Is the shifter sloppy?
· Registered
does it make noise trying to put into first, or is it a "quiet resistance" ?
if it is quiet, maybe clutch needs bled or adjustment. full procedure in service man
if it makes noise, could be synchros, throwout release bearing assembly, forks lots of stuff.
once you get it goin is the trans quiet or very noisy?
if idling and you push in the clutch pedal does it start making a noise? (throwout bearing)
is this 5spd or 6spd?
1 - 9 of 9 Posts
