1 - 8 of 8 Posts
Hey guys, just bought a new 2019 WRX love the car already. Already toying the idea of full exhaust and a tune (i'm assuming it will void the warranty) but, need to ask, how reliable are these engine with after tuning and some bolt-on's?
Super Moderator
Fairly, however failures are not uncommon.
Have had my exhaust from the turbo back and tuned for over two years on my 2016 WRX and have had no issues. Had a check engine light come on last year for a oil sending unit sensor? But do not think it came on from my mods and tune just was normal engine issue. Was able to get a performance Perrin air intake without a tune, would suggest that as your first mod but no pro here. Todd
Discussion Starter · #4 ·
Ive heard that intake tune and exhaust unlocks quite a bit of hp, is that true?
Super Moderator
On the fa20f in the 15+ wrx not as much as previously. The exhaust side of things is far more efficient and well designed.
The fa20f responds better on the intake side of things. Intake, tgv and egr deletes and so on. If horsepower is your ultimate goal and you need Dyno results that's been the consensus so far. The exhaust does free up some power though.
Discussion Starter · #6 ·
Welp first order of business, intake and a cobb, thanks for the help!
Super Moderator
If you are only doing the intake and that's all you won't see the huge bump from the egr and tgv delete. That's where the restriction is. However you'll see a fair return on investment as you'll get about the same power for less parts cost.
The required Cobb big sf intake is 300 or less where the downpipe is upwards of 600.
Discussion Starter · #8 ·
Hmm ill have to look into those also, i know nothing about this engine or platform (flat 4) so im starting to do research and figuring out a game plan so i can get these knocked out once the car is out of powertrain warranty.
1 - 8 of 8 Posts
