About the blow off valve. NO. Like they said, don't even waste the time. Number one it cannot be tuned for to be made safe, and secondly, running an atmospheric bov can damage your car as our cars are set up with a recirculator valve.
Perrin makes decent intakes. I have had perrin intakes on 2 of my prior wrx's. Only problem is that it WILL NOT work with the map from cobb's accessport. For your model wrx the only intakes that cobb supports is their own SF intake, and the AEM intake. There are separate maps available for either one of those from cobb. The SF intake map will already be preloaded on the accessport, the aem intake map can be downloaded via cobb's website. IF you were to go with the perrin intake you would have to shell out extra money for a protune or at least an etune to run it safely. And protuning with just an intake is a waste of money. If you wanted to get the perrin intake, get it and set it aside until you get more mods to add to it before protuning. For instance, if it were me I would get the perrin intake, turbo back exhaust, 3 port electronic boost control solenoid, injectors, and fuel pump at the minimum before paying for a protune. But if you are just wanting to go stage 1 with the accessport for now, one of the above mentioned intakes (cobb SF, or AEM) would have to be the way to go.
