Vendor
If you want to improve the performance of your car without any serious modifications, you should definitely consider installing a performance air intake and exhaust system. Upgrading to an aftermarket air intake system will help you to squeeze a couple of extra HPs out of your engine and today we are here with the new option to look at - 69 Series Typhoon Aluminum Red Cold Air Intake System by K&N.
It replaces the factory air intake system with a free flowing K&N air filter and custom designed air intake tube. As a result, you get better acceleration, improved airflow and increased horsepower you can feel once this kit is installed.
K&N® - 69 Series Typhoon Aluminum Red Cold Air Intake System with Red Filter
Features:
- Material: Aluminum
- HP Gain: up to 25.2 hp
- Custom designed and engineered for each application
- Works with OEM computer system
- Easy to install
- Up to 100,000 miles between servicing
- Million Mile limited warranty.
K&N™ | Filters & Cold Air Intakes - CARiD.com
Whether you drive your Impreza on the highway or on the track, you will definitely appreciate K&N 69 Series Typhoon Aluminum Red Cold Air Intake System from CARiD!​
