1 - 12 of 12 Posts
So I’m looking at getting a pair of winter rims and tires for my 19 STI . I was just wondering if I wanted to go down to a 18’ would I change the offset? Or would a stock 18’ STI rims work ? Thanks
Super Moderator
If the wheel is the same width as the factory wheel no.
However it's ideal to have narrower winter tires.
Discussion Starter · #3 ·
I’m just worried about the rim hitting the calipers . The stock rims are very close as it is , so that’s why I was asking
Super Moderator
At some point the brakes changed, I don't know if it was 18, or 19. If the 18s have the same brakes and 18" wheels then they will fit
Æternum
Nice thanks same offset as the stock rims are +55?
Yes, offset is +55
OP -- not all 18" wheels are the same. You would be well advised to find other cases of people installing 18" wheels on the new 6-piston brake hubs. Or you could volunteer as tribute ;)
1 - 12 of 12 Posts
