1 - 3 of 3 Posts
So last August I bought a 2015 wrx . It had 30k on it and no mods . I noticed just recently when I come to a light it has a rough idle . I’m also new to these cars . I have owned Mazda rx 7s they have there own set of rules and things that go wrong with that car type. I also have a question of u drive these cars hard so there burn oil and coolant . My from end is also making a buzzing noise but when I turn the heat off it stops in the front end . Sorry for bouncing around just some much in the last month that’s happening . I don’t want anything to happen to this car. I also bought extended warranty with it .
some say the rough idle at a stop is normal. i duno.
these cars CAN burn coolant and oil, just make sure you check often and do regular oil changes.
the buzzing noise might just be the AC compressor turning off n on, i know that the car runs at a higher idle when you turn the heater on.
Æternum
Turn off your HVAC system and see if the "shake" goes away.
Nine times out of ten, the complaint is from the A/C compressor kicking on. And yes -- the A/C compressor runs in the winter when you have the defrost or auto climate control on.
1 - 3 of 3 Posts
