1 - 17 of 17 Posts
ive got an 04 wrx putting in 2.1 stroker kit forged pistons................ now what ? i need like a list of what i need to do so i can start looking for people to do it. i live in michigan SE that is near ohio. need names and contacts. everything from clutch to injectors im buying perrin set-up, what kind of turbo something that will last i heard turbonetics ? using 2.5 oil pan and pick-up upgraded oil pump so that perrin headers will fit. do i even need to worry about cams and should i get good springs and retainers even without the cam upgrade ? first turbo car first subaru im lost and need help motor is apart and parts are on the way project will begin next week i kinda need start to finish lists for what works
thanks everyone that helps i need info and dont know where to start :screwy:
My best advise would be to figure out who will be tuning the car and ask them what it takes to get 450hp out of their dyno with your car, then go from there.
Not trying to be rude, but I hope you know how ridiculous of a number 450awhp is.
Sound advice about choosing your tuning shop and asking them. They'll know their dyno/work best.
That said, there are many ways to skin a cat. I would go rotated over stock location. You'll hit your numbers more efficiently (READ: safer). A GTX30R, for example, shouldn't have trouble on E85/pump+meth, if not pump alone.
What you should be shooting for is up to you. I'm just saying that 450awhp is a very high goal. You're in for a lot and a lot of money.
As I said, get together with your tuner and discuss your goals and a plan to achieve them.
Discussion Starter #7
need help with 450+ build
atleast 400 hp i want my cell is 734-286-8272
[email protected]
you probably need to post a few shops here, catch a few reviews from us about the shops, choose one your comfortable with then talk to them about your build. We can tell you what you should do all day long, but that pertains typically to our dyno. We are all willing to help but what it boils down to is nobody knows the dyno you choose better than the technician trained to run it.
You're gonna need headwork and cams if you wanna make it there easy.
Gold Member
holy crap u guys wasnt kiddin $$$$$$$$$$$ lol thanks for the heads up
Yep. My friend just recently cut a check for $23K to fully rebuild his 08 STI, and he's still short of 450awhp (on their dyno).
Holy crap. I'm glad I was only going for 300ish with my build. And that put a strain on the finances for a little while. :rotfl:
He's doing it wrong. My tuner is over 550 and is in it (motor and turbo) less than 15.
Gold Member
True, he probably could have have got more power for less. That cost also includes motor/internals, turbo, trans, clutch, 50/50 hydramist, tune and other goodies.
Discussion Starter #16
yeah i talked to a guy said hes runnin 600 whp to stock sti axles with np but im looking at 300 max on a stock wrx trans gotta find a sti trans for sale cheap and rear end plus axles and bigger brakes
What? Why? You really don't need to upgrade your axles.
1 - 17 of 17 Posts
