1 - 4 of 4 Posts
i just recent got my wrx 03 completely stock still haven't done anything to yet cause it need a little work. Lately ive noticed my turbo doesn't seem to be working to its fullest potential but im not positive im new to the turbo engine. it just feels like its really lagging but then again i'm not positive. does a turbo need a tune? or something?
and please list anything else that i should also know about the turbo and tune ups please. i really need help.
FIRST!!! Compression/leakdown test is what you should do before investigating any other issues. You may have just gotten used to the way the car feels.
Yes that would be a good place to start to know how well the engine is functioning. How many miles are on the car?
This is what I recommend on a new to you car..
Compression and leak down tests.
New Spark plugs cuz you pulled em out anyway
Pressure test the cooling system
If the engine passes the tests:
Change engine oil/filter
Air filter
Fuel filter
(already changed plugs)
change diff fluid
change trans fluid
check brake fluid/clutch fluid
visually inspect brakes, pull wheels off and inspect inside/outside pads
get an alignment
1 - 4 of 4 Posts
