1 - 4 of 4 Posts
hey guys im p*ssed off now-- after installing morette taillights from my friends house i drove home to shower. I hopped back into my car and it RUNS LIKE CRAP and my speedo dont work but everything else does.
It was fine before but these are the codes that popped up on my Access Port --
p1507 Idel Malfunction / (Fail Safe)
p0457 Gas Cap <--- has always been a problem.
p0500 Speed sensor
what could have happened ? ?
MODs
vf34 stage 4 Cobb Access Port
WOW THAT SUKED!
well i figured out the problem --
This is what happed to the car
the ABS light would go on when i shift into reverse
my headlights would stay on when the lights are off ( no DRL)
Fan would stay on even when off
idle was at 1500 rpm
my speedo was not reading
3 codes pulled
what happed you ask ? one of my wires came loose from installing my taillights and was touching the chasse which blew a fuse and did something to the ecu ..
Fixed the wire / replaced the fuse / reset ECU
im happy !
1 - 4 of 4 Posts
