1 - 9 of 9 Posts
OK so here is the problem 3 days ago i got the pioneer Deh -9300 single din radio and me and my friends installed it the install went well the radio worked fine but as soon as i started the car the speakers began to make a horrible noise which got louder with the engine reving (and yes i did run the power wire and the rca wires alone oppisite sides of the car) so we took the radio out to check the wires so my friend took the harness off and redid the tape nice and tight and we put the radio back in
and now we get no sound what so ever the radio is on and all the displays are showing music but the speakers wont work
help me audio gods
We did also try the stock radio so the speakers are working:D
I'm lost give some more details on your setup. Are you running all 4 speakers off an amp? Check your RCAs, ground wire, and remote turn on lead. That horrible noise sounds like a bad ground loop. Was it kinda like a whiny noise that increased with RPM?
Discussion Starter · #3 ·
No im using the stock internal speakers the rcas seem fine they are monster wire brand new and yes the whine was like a screeech that gets louder with the engine revs the
Dude, that sound is from your alternator. You are getting signal feedback....probably your wires are not shielded...make sure that you never run the RCA cables along the car with ANY type of wire...beit power wire or even the remote wire. Attempt to isolate your signal wires and you should be all good.
Sheilded wire is key but that sounds more like a bad ground loop to me...where do you have the amp grounded? Make sure its a clean ground and short as possible. Kinda hard to avoid running your RCA along any kind of wire w/o tearing the entire car apart but a good set of RCAs should be sheilded to prevent that feedback.
everything works except for no sound....oh no...this happened to me once....did you, by mistake expose the remote wire to metal while the unit was on?? If you are not using the remote wire, which if you dont have an amp you are not, be sure to COVER it with a wire cap....you dont want that wire touching metal while the radio is in operation or good-bye fuse....what you have is a fuse problem i think...you have blown a fuse in the headunit...but check the fuses in your fuse box as well...also check the wire harness and be sure that all the wires are intact and that they are secured to the harness correctly.
By the way...you should use screw on wire tips b/c in the summer, that electrical tape is going to melt and make a sticky mess....with the caps you dont have to worry about any unwanted impedance (because don't forget that the electrical tape is an insulator and you dont want any remnants of the tape adhesive blocking your signal.)
Good point Knight you dont want that remote lead exposed b/c its 12v switched power....BUT he did say the head unit still turns on so if it was a blown fuse the head unit woundnt turn on at all and some of the dash lights would probably be out as well. I've done that in the past. Its hard to diagonis without being there to see it :(
1 - 9 of 9 Posts
