323582
323583
323584
this is my vehicle after the crash happened, as well as after i got done tearing everything down. I am currently down to the frame rails the core support is crushed as you can see, as well as the unrails are bent a bit. The good side of things is that the new front end only cost 1500 bucks as you can see in the top picture you the unrails can be cut and if they are cut then what would be the best way of putting on a new front clip, basically get it back on wether or not its is totaled. I am aware of the damage and that is done and that fabrication and frame work is a hard thing, i am just a very passionate kid for cars and I would appreciate some feed back
