1 - 20 of 38 Posts
So the other day i bought the new prosport halo series boost gauge. Got all the electrical ran saturday and hooked the vacuum lines up yesterday... everything works great and the gauge is really nice. The only question i have is when im at full boost its only showing between 10-12 psi. is this normal for stock? everything else about it seems right on but im just not sure what the factory boost should be hitting... :confused:
That's low brother, stock form is 14.2 I believe on the WRX, 14.5-.7 on the STi
hmm... i'll have to check everything out to make sure i dont have a vacuum line kinked maybe where it goes through the firewall... That boost gauge comes with a inline filter and all that.. Would you think taking that out would make it read better?
Perhaps a dumb question, but when the car is off, does it settle to zero?
Yes sir. Everything about it seems right. when the car is off it registers zero. Ive read that some boost between 10-12 is normal but like sam said it seemed low to me
Definitely seems a little low to me.
Ray also brings up a good point too....My prosport gauge reads like 1 line under 0 when off, so I know that it's like 1psi off.
Discussion Starter #7
well when i first drove home it would show like you said 1 line under.. but now it registers zero and only goes up to maybe 10 to 11.. so even at that it would be a little low.
Yea, agreed....
Have you checked for any kinks in the line as you said earlier? I have the inline filter in mine and all, that doesn't mess up the reading at all for me. Maybe just go over all your hose connections one last time and make sure that they are on 100%.
Discussion Starter #9
Yea, agreed....
I did last night and couldnt find any... Im gonna go over it again this evening when i get home and check where i went through the firewall and see if thats where.... You said you had the prosport.. what does your boost level read? I know you have stage 2 and all but just curious
I'm stg2 with the sf intake and a Cobb OTS tune. I'm right at 18psi, exactly where I should be.
Discussion Starter #12
oh ok. im getting ready to go stage 1 and then later on stage 2. i was just wondering what i should be looking for. i just remember reading that stage 1 and 2 your boost will go up quite a bit. Its not that my boost gauge is a issue. but i definately would like it to be pretty close for when i do go stage 1 and 2 just to keep track of it.. right now its not a big deal. just enough to annoy you though. lol.
You can pull the gauge out and adjust it to zero. There is a small access hole on the back pf the gauge.
Sent from my DROIDX using Tapatalk
I never knew this!! I love you right now.
Discussion Starter #17
Maybe try doing a WOT pull & see what happens.
I will when i get off work this evening. it just seemed to me on my way to work this morning its like it would hit 11 or 12 and just stop and wouldnt go above that at all. At what gear or rpms should i see peak boost levels?
Discussion Starter #19
At redline in 3rd gear.
well maybe thats my problem. maybe i was just stupid enough to think something was wrong.. i just woulda thought it should be reading higher. if im reading 10-12 at 4-5000 then maybe at red line it should jump more.. I guess we'll see though
1 - 20 of 38 Posts
