1 - 20 of 25 Posts
SO my WRX hit 3K miles. I figure I'll change my oil cause that's how I was raised. I'm saving switching to synthetic till my next change (seems to be a consensus from this board).
I bought a Bosch filter and Valvoline 10-30 oil. I use to drive a Ford pick-up before, so I couldn't believe how small these filters were. I got an adjustable do-hicky w/ 3 clamping arms for the filter.
Did anybody else have trouble getting the bolt off? I almost gave up and considered taking her in. Once I got the bolt loose, the oil came out clean, but I could feel some metal shavings ( got me wishing I had changed earlier).
Getting the filter off was a pain also...the location is close and convenient, but I was having quite a difficult time clamping on and turning. When it came time to put the new one on, I pretty much gave up using the clamp. I just turned the thing on by hand. Seemed tight enough.
As for filling up the oil...I had a 5 liter jug which I pretty much emptied. I know it's suppose to be less, but checking the dip stick, like 5 times, I think I was able to get it just below the "F" hole.
I've changed the oil in my truck a whole lot...I don't know how precise the amount of oil needs to be. Can someone let me know if I did something heinous here?
Still learning...
dan.
Sounds like you did everything right, Dan.
I hear 'ya on the filter location. It'd probably be a lot easier to get to it if you take off that plastic undertray thing, but that's extra labor in itself so it wouldn't save any time. I use one of those strap things where you put the cloth strap on the filter and tighten that with the metal part which you attach your ratchet to, then turn it. Got it for my motorcycles but it works okay on the car too.
The manual says to turn the filter 2/3 of a full turn after your seal makes contact with the filter housing. Well, that's pretty much equal to how far you can hand-tighten it, so what you did is fine.
Discussion Starter · #4 ·
Thanks for setting my mind at ease...I log about 100 miles on my daily commute, so oil changing will be like once a month. PlatWRX, didn't know about the hand-tight filter thing...hey, it makes my life easier!
BTW, I have this board up almost all day at work...I like the way people provide solid feedback and also the casual conversations. It encourages me to post more often.
Hope to know all of yoos better,
dan.
HOLY GEEZ! Ok, so I did my first oil change today. My GAWD was the plug AND filter hard as ANYTHING to get off! But, alas, my brute strength conqured :D lol Oil changed, in the process of doing the grounding mod and scoop mesh!
LOL. I'm not sure if they use a robot or a Sumo to tighten those things at the factory!
I use a bigass channel-lock to get my filter off.
Just 2/3 of a turn after the gasket contacts the mount hand tightening. In high school my best friend was a football player. Big black guy, about 6'0" 230 pounds, 5% body fat. Fullback. We were changing the oil on his car and he hand tightened the filter - only he twisted it so far with his huge hand that he blew the gasket off the filter! It just squeezed out the side. Lucky he didn't strip the threads off of the mount! We had to take it back and get a new one. The parts guy was like "gee, I never saw that happen before!". LOL
Just about emptying a 5 gallon jug is about right. 4.7 qt. Or is it 4.8? I forget - I keep it written on my garage's white board.
Chris
dan.
Addicting, ain't it?
I've never done an oil change on any car before, but i want to start doing them on this one. Do you have to change the oil filter when you change the oil? What kind of oil do you recommend? I'll switch to synthetic at 6000 miles. :cool:
I use the OEM, a little expensive but they give me a new crush washer for the plug, which was not on my car from the factory.
You may want to check the oil plug next time you change your oil. The crush washer was pretty much stuck to the plug from getting painted at the factory. I had to pry it off with a screwdriver.
I gave my new 2011 rex its first oil change last nite. Next time it will only take 20 minutes. Once I figured out how to release those tricky plastic fasteners from the bottom cover, it all went well. (The center button has to pop out 1/2" before you can pry out the rest of it).
I slipped a regular filter wrench over the filter then tucked the handle over the exhaust header, which gave me about 20 degrees of swing.
What's this about not going synthetic until 2nd change? Whatever the factory had in it came out so clear I might re-use it in my truck!
Pro Manscaper
At least we know the search function is working :)
Can I leave a message to 2002 me and could someone make sure I find it?
1 - 20 of 25 Posts
