1 - 5 of 5 Posts
So...on a day of hard accelerating....
What's the normal MPa levels I should see in each gear? Thanks for the help.
Kemo
The ECU pulls boost at higher RPM's
1st & 2nd don't hit peak
3rd, 4th, & 5th average .092mpa
i've hit peak in second before (car not quite broken in), right up near 0.10 mpa. who said you can't hit 14.5 psi in second with a stock wrx? have yet to hit it in first.
in order to hit this peak you'll need to floor it. casual hard acceleration won't cut it. general hard acceleration will get you half a bar or 0.05 mpa on the gauge.
1 - 5 of 5 Posts
