1 - 2 of 2 Posts
had my 2003 wrx for about 4 months now and yesterday i put on a catless up pipe that i got from someone in trade. the pipe was already heat wrapped and i sprayed it with the high temp silicone in an attempt to keep some moisture away from it.. fallowed the instructions and heated the pipe after i painted it to cook the paint on.. then it sat for a couple weeks till i got a day off to install..
Now its on and when the car is heated up it smokes like its the end of the world. i can see the clouds behind me as i drive and when i stop its as if the engine is on fire its coming out ever were.. i have done heat wrap on other cars and this seems way worse then usuall.. any ideas on whats going on here.. im used to exhaust wrap smoking but this is day two and its still like a cloud around me
ive had heat wrap smoke and smell for around a week before. just look under and make sure the wrap that is smoking, not a leak or something. and also recheck and make sure it was the right kind of wrap
1 - 2 of 2 Posts
