1 - 3 of 3 Posts
2002 Subaru WRX
106,xxx miles
Black
EJ257 with VF39
Located in Rochester, MN
The car is in great shape with new motor and suspension parts. I'm selling the car because it was my daily driver and I don't need this much power anymore and I'm not into racing. I did an EJ257 swap this past winter to add some much needed torque with a brand new EJ257 block from Ron at Raw Performance and CP forged pistons. Ron also rebuilt the stock EJ207 heads so it is a hybrid setup. Dyno tuned at DB Performance with 297awhp and 315awtq which equates to about 380hp and 400tq. The car is deceivingly fast and is a total sleeper with the spoiler removed and the trunk lid debadged. I have almost all of my receipts. Everything works and the car runs great!
Engine
-EJ257 currently with 5,000 miles
-CP forged pistons
-Professionally rebuilt heads
-Cometic head gaskets
-VF39 PnP'd by Grimmspeed with ceramic coating
-STI Pink injectors professionally cleaned at RC Engineering with print out
-Throttle body PnP'd by Grimmspeed
-Perrin turbo inlet and elbow with new K&N air filter
-Grimmspeed electronic boost control solenoid
-TGV's removed
-Gates Racing timing belt and new OEM tensioner
-Gates Racing alternator and a/c belts
-TurboXS TMIC
-HKS BOV
-Walbro 255 fuel pump
-STI oil pan and dipstick
-Killer B Motorsport Ultimate oil pickup
-New PCV valve
-New fuel filter
-New NGK copper spark plugs after engine break in period
-Group N motor and transmission mounts with Kartboy transmission crossmember bushings
-ARP head studs
-STI 11mm oil pump
-New waterpump and tstat at time of new engine
-New front O2 sensor
-O2 bung after downpipe with plug installed
Exhaust
-TurboXS turbo-back with 4" downpipe ceramic coated by Grimmspeed
-Stock exhaust manifold PnP'd by Grimmspeed with the Grimmspeed high flow cross pipe all ceramic coated and double thick gaskets
-Grimmspeed flex catless uppipe ceramic coated
Suspension
-Koni Sport adjustable struts
-Eibach springs
-Group N strut mounts
-STI aluminum front control arms
Brakes
-DBA 4000 rotors
-Hawk HPS pads
-H6 rear rotor upgrade
-Black painted calipers
Miscellaneous
-Black headlights
-JDM STI hood scoop and splitter
-Black front side turn signals
-Spoiler professionally removed
-Shaved trunk lid
-Momo shift knob with real leather boot
-OEM WRX carpet floor mats and OEM rubber mats
-Tinted windows
-Yokohama YK520 tires with about 8/32nds left
1 - 3 of 3 Posts
